New Bronco!
What do you think of the new Concept Bronco?
  • It's awesome
    Votes: 0 0.0%
  • Pretty cool
    Votes: 0 0.0%
  • Yuppy Mobile
    Votes: 0 0.0%
  • Hate it
    Votes: 0 0.0%
  • Total voters
    0
admin
Member
Unveiled this year at the North American International Auto Show, a concept version of Ford's pioneering 1960s sport utility vehicle retains the original Bronco's authentic, no-nonsense design and adds a turbocharged diesel engine for added kick.
While other sport utilities become more civilized, the Bronco concept bucks this trend in a simple two-seat design that features the same rugged good looks as its predecessor. It is instantly recognizable in shape. Reminiscent of the original Bronco are its boxy, upright roofline, short wheelbase, signature round headlamps and the Bronco name integrated into a modern three bar grille.
"True to its heritage, the Bronco concept is a tough, genuine SUV that's all about function," says J Mays, Ford Motor Company group vice president of design. "It's like a claw hammer in a box full of department store, battery-operated, plastic, power tools."
Subtle exterior details include exposed door hinges, cowl vents, flared wheel wells and unique loop-shaped door handles, which are integrated into the door panels and open with a gentle tug. Those classic round headlamps up front are updated in the Bronco concept for use of both light-emitting diodes and halogen light sources to cast a wider ray of light for better peripheral vision in off-road situations.
For a more open-air ride, the Bronco concept's roof is made up of two separate sections, the rear portion of which can be removed. Roll bar accents can then be attached for a look that recalls a Baja racer or the customized "Baja Broncos" Ford offered in the 1970s.
A monotone color scheme flows seamlessly from the Bronco concept's exterior body panels to its interior surfaces.
A monotone color scheme features warm metallic gray finish coupled with brushed aluminum accents and flows seamlessly from the Bronco concept's exterior body panels to its exposed interior surfaces. Both seats are trimmed in orange brown suede, like a workman's glove, and are accented with similarly colored inserts and a four-line stitching pattern, like the kind found on a rugged old tool belt.
"The Bronco concept is like your favorite pair of worn in, faded jeans classic, familiar, comfortable and always in style," says Mays.
While the Bronco concept conjures memories of blue oval past, inside it is a showcase of advanced modern technology. Its power comes from a 2.0-liter, 16-valve intercooled turbo-diesel engine tucked under the hood. First introduced on the Ford Mondeo in Europe, this engine features common-rail fuel injection technology for greater injection precision, performance and torque, without sacrificing fuel economy. The Duratorq TDCi, as its known, delivers 128 horsepower and a peak torque of 244 foot-pounds. Using Ford's overboost function generates an even higher torque of 258 foot-pounds for a limited time under full throttle.
Adding to the Bronco concept's power is a nitrous oxide "boost," similar to the power enhancement function of traditional hot rods. At the press of a button, a blast of nitrous oxide is injected into the engine. During combustion, the gas is broken down into nitrogen and oxygen, allowing more fuel to burn.
What does all that mean? An extra temporary boost of up to 50 horsepower and a three-second improvement in quarter-mile times, with about 10-15 mph more top speed.
A revolutionary new six-speed PowerShift transmission is paired with the Duratorq diesel and achieves 5 percent better fuel economy than a conventional six-speed automatic transmission. While a traditional manual or automatic transmission changes gears by opening and closing a single clutch, the PowerShift operates by shifting power from one clutch to another for better efficiency and more seamless shifting. It can be placed into manual mode at anytime and operated by a pair of shift paddles on the steering wheel.
Rounding out the Bronco concept's technology showcase is an IntelligentTM four-wheel-drive system a fully computer-controlled clutch that engages the rear wheels as driving conditions dictate. Under normal conditions, the Bronco gallops on its front wheels. Using sensors at each wheel and at the accelerator, the Intelligent system's computer calculates dozens of times per second to determine precisely how much torque should be sent to the rear wheels to minimize and help prevent wheel slippage.
The new Intelligent system replaces Ford's current Control Trac IITM system for more positive traction and vehicle handling, improved fuel economy and smoother operation. It will first be seen in production on the 2005 Ford Escape.
The original Bronco was an immediate success when it launched in August 1965, leading the emerging recreational four-wheel-drive market with sales of 18,200 units in its first full year of production. Although only a concept, this year's Bronco concept demonstrates how Ford may further complement its extensive SUV lineup.
All content curteosy of media.ford.com
Here are some other topics in this forum discussing this truck...
http://broncozone.com/forums/index.php?act=ST&f=3&t=20
http://broncozone.com/forums/index.php?act=ST&f=3&t=23
I like the idea of the diesel engine. When this truck is introduced I will be very interested. It will accent my '74.
im very interested in the concept of a new bronco. They should have never got ride of them i got one of the last ones man so hope to see a new one
later arcticwolf
i like
yes it's yup but istill want one
live axel's
37's
Sadly, you'll never see live axles from Ford again, nor will you ever see anything bigger than some 32" sized metric tires being offered, if they're even available that big as an option. Being a FWD little SUV, I wouldn't expect much from it, other than looks
A front wheel drive bronco need i say more ... i think it looks mean as hell i could deal with the diesel but NOT FWD AHH someone call ford and kik the desighn ten in the teath please .Thats what it felt like to read that it was FWD . And they realy have to put a set of axels on the thing
(this is my first post here)
I have owned many broncos. my first being a 78, the next an 85 then an 86 and finally, my 95 xlt. I have loved and lost nearly all of them in numerous stunts and accidents. The new bronco looks pretty sweet. It could have been done better, but the resemblance to the old scouts looks pretty damn cool. It'd be a mean addition to any subdivisioned housewife's suburban arsenal.
I think the retro styling is good but the mechanicals are pure yuppie mobile. Too much electronics and an overly complicated drivetrain. Give me a 4.6 liter V-8 and a good non electronic Dana drivetrain. The original was very simple mechanically and this one shoud be too.
They still sell lots of Jeeps using simple drivetrains.
QUOTE (FWDbroncoNOWAY @ Jan 12 2004, 07:37 PM) A front wheel drive bronco need i say more ... i think it looks mean as hell i could deal with the diesel but NOT FWD AHH someone call ford and kik the desighn ten in the teath please .Thats what it felt like to read that it was FWD . And they realy have to put a set of axels on the thing
I concur..... :((
i own a 94 full size bronco.... and i was sitting here looking at the new concept and i think it is the ugliest truck i have ever seen... i love bronco but this one made me nerely puke.... it is uglier than shit....
I think they should have put me on the design team LOL
anywayz I like he idea of a new retro Bronco > but i think the design needs improvement. I dont particularly like the grill, reminds me too much of a hummer. Next > I do not like diesel, just personal opinion.
Definately needs to be topless for my taste as well :D
I just can't get oer the FWD. I also can't get over the stock puny HP Rating(128). Hell my moms PT Cruiser has more HP than that. I think that it looks cool and all, but even though it looks like a Bronco it sure as hell sounds like it won't drive like one. Ins't that what made the frist bronco so popular? Isn't that why we drive them today? You could actually take it off road to places that no one had gone before (as a weekender). Besides with all this new Tech crap sounds real good, but it turns something as wonderful and pure as a 4X4 into an AWD vehicle. All and all this new Bronco(in name only) sucks. I would defenently not trade my old 86 for a new one at any cost.
The new Bronco is ok. I don't like the tailgate though, or the fact that it's FWD. What were they thinking? :angry:
i like the outside design with retro quews and the nitrous but the fwd is another story. desiel would be fine with a powerstroke and 650 lbs ft of torque at least for the show. ford should revert to old tactics and base it on an f-150 with similar drivetrain and engine options. but none of the touchey feely stuff like dvd players for the kidlets. we need another wrangler killer!!!
It'd be great if we could get our Bronco parts supply guys ( JBG, Wild Horses, James Duff, Tom's, and others) to come up with a concept to pitch to Ford. I bet they could come up with a Bronc that would fit in today's vehicle market and still have the genes of an early Bronco. I seriously doubt Ford would even pay attention. We can hope for now.
EWWWW! I hate it! icky icky icky. what were they doing, with the fwd? and the diesel? and the hp? ewwwww. id rather buy a go cart and go driving in that! im keeping my 78 and to hell with the new one.
Front wheel drive :)) no live axles [-X I do like the diesel and nos
:rolleyes: Please FWD I guess ford had their heads up their, Anyway I bet the women that buy it will love it. :D
