When I got underneath and did a little exploring from different angles I saw oil leaking from the rear of the passenger side valve cover. I pulled the intake manifold off and and the valve cover and replaced the gasket. Had to tap a couple of the bolt holes which sucked, but finally got it back together. The pipe that leads from the lower intake manifold to what I believe is the EGR sensor was rusted through so I replaced it and several hoses that were worn. I just finished putting it together about an hour ago, and its too dark to see if it is still smoking or not. I dont smell it anymore though. One day I will have a garage, and it will be filled with tools, and there will be lots of lights, so I can work whenever I want. One day...
