dmattingly1
I been having trouble with my 1992 FORD F 150 5.0 MPI it seems to run good unless you push on it a little and when it hits second gear it just flattens out and tries to die.I replaced wires, plugs , cap, map sensor, oxygen sensor, had the converters checked and I'm still having same problem.Aso replaced fuel filter.I'm getting a throttle position sensor code out of computer but I've never seen a tps create a problem other than an idle problem and it idles perfect. I was wondering if anybody had encountered a similar problem.
dmattingly1
dmattingly1
