Starting Problems
Fisherleep
I replaced my hacked up 69 wire harness with a good used 75 wire harness because the old harness the previous owner had cut it all up and converted it to an electronic ignition also dropping in a 79 302 it ran if you wiggled the wires just right so I got the used one. My problem is that when I turn the key nothing happens, there is a new starter motor relay, ignition switch, ignition key and cylinder all wire are connected correctly that I know of checked many times, good ground. I have a manual on the floor and the 75 harness is from an automatic does any one know if that could be the problem because I don't have a neutral safety switch hooked up to anything? Is that why it does not want to start because it thinks its in gear? If so should I get a switch to plug into the harness to trick it to think it's in park or is there a way to cut the plug and connect wires into fooling it if so what colors? Any other opinions of what could be wrong will greatly be appreciated
Post only in one place. I replied in the other forum before I noticed you had duplicate posts. This actually is the right place to post technical questions :D .
Welcome to the Zone
