7
74bronx
Hi,
I just recently purchase a 74 bronco. It has a 302 and a 3 speed manual. when I first drove it, 2nd gear wouldn't work so after looking at the linkage I was able to get it to go in all 3 gears but the thing is when I put the transfer case into 2h or moveed it in any way it jammed the shift rods to where it wouldn't go into 2nd I feel the shifting rods are wrong or mybe bent, is this possible? Should I just order new ones? What is the easiest way to adjust the linkage from scratch?
P.S.> Should the two shift brackets on the trans, (where the rods meet the trans) which way should they be mounted? Up or down?
Thanks
TD
Thanks
TD
