Power Steering Converition
  • Thread starter Thread starter ddspanker
D
ddspanker
Hi
Bob in Tucson, I have a 71 Ford Bronco and want to convert to power steering. Other then the steering box, pump, mounting bracket, and hoses what will I need to make the converition? Second question is there anywhere to buy these parts so I do not have to take out a second morgage?
P.S. I plan on a 3.5" lift.
Thanks!
Check out this site..www.broncoconnection.net..He sells used original parts and has lots!Also www.bcbroncos.com has the F-150 conversion info on their site and even has a tech article and tells you what you need.Otherwise you might luck up and find someone with a spare piece here and there and piece it together.Power steering is a nice easy install on a Bronco and does it ever beat armstrong steering.Good luck!
i have a power steering conversion on my 72 and its the f-100 box and you have to have a bracket to mount it to the frame which you will prolly have to have with any of them
