9
95XLT
W....T....F
Changed my oil about 3 weeks back... probably put on about 2,000 miles or so, it's been a busy month.
Got a Fram oil filter, checked the size, everything is correct, wondering if it is not on tight enough? After I first saw the leakage on the ground, I tightened it as hard as I could
Then I wondered if it was the bolt on the bottom of the oil pan. Checked today, not wet at all
Everything under that filter though is completely saturated with a substance, too hard to distinguish, but I would bet it is oil. I dont understand how it could be tightened but still drip, unless it is the wrong size
