Iamnottelling
On my bronco the rubber bushing is bad adn I have to replace it. The bushing is on the "A arm" that holds the front axle from coming back. I am not sure the proper name for it? It has a 1 1/8 nut on the end that I will have to cut off and crack due to rust and the inability to get it off. I was told by someone that I will be able to pull that whole aparatus forward the 3-4" that is needed to slip the new bushing on and then slide it back into the braket that holds it to the frame. Do I have to remove the bracket (3 nuts and bolts that may need to be cut and replaced) ?
If I wasnt' at work 500 miles from my truck i would add a pic.
