I NEED INFO ON SWAPPING A 1986 460 INTO A 1977 F150 WITH A 400M AND 435 4SPEED WITH A 205 TRANSFER CASE WONDERING WHAT I NEED MOTOR MOUNTS' FLYWHEEL'CLUTCH'PRESSUREPLATE WILL AN 11" DISC WORK OR DO I NEED A 12"DISC WILL MY EXISTING BELL HOUSING WORK WITH SHIMS OR DO I NEED A DIFFERENT HOUSING I PLAN USING STOCK MANIFOLDS FOR KNOW AND I'M GETTING AN ALUMINUM INTAKE FROM SUMMIT SO I CAN ELIMINATE ALL THE SMOG STUFF ON THE NEWER MOTOR ANY INFO WOULD BE APPRECIATED SO I'M NOT GOING INTO THIS BLIND THANKS
