the frames are basicly the same from 65 to 79 they are the same the only difference is that you might have to cut body mount holes in the crossmember of your frame for the rear body mounts, check to see if your body mounts are inside the framerail, or outside and compare, and also if you are swapping man/auto tranies you will ned to change things.
