Tranny Slips! Gears Take A While To Catch
  • Thread starter Thread starter Mikey
M
Mikey
I got a 89 bronco with 5.0 V8 engine. I just got back from The Gulf of Mexico. Some Nice races down there by the way. Well on my way back which was about a hour drive, my gears weren't catching. I was going only about 35 MPH and I couldn't go faster. After about 30 minutes, the gears shifted themselves and it was fine. I checked the ATF and it was full and my oil was missing a quart so i put it in. Now my Transmission takes a while to react and its brand new. It was changed and flushed 3 months prior but was leaking a little bit from transfer case. Any suggestions out there from anybody. <):)
Mine slips a lot every once and a while, yesterday i pulled uot of my drive way and gunned it and it didnt go anywhere!! took about 5 seconds to catch, always takes a few seconds in between changing gears also, any help would be appreciated by both of us, thank you
Turner
you could have goop in the valves and servos. this causes a drop in pressure and doesn't allow it to shift and engage gears. mabey new filter and flush or a rebuild.
Another two cents, did you put in a new torque converter when you did the trany? If not, it may be the problem. Take it to your local friendly trany guy.
Good luck, :)>-
