Trac-bar 74 Bronco
  • Thread starter Thread starter PNath
P
PNath
Hello, I have a 74 Ford Bronco and it has a 3.5in lift. The front end seems to be shifted to the passengers side. Everyone tells me that I do not need a longer trac-bar. Is it a track bar proble? The frame is fine, no damage. I am new at this any help apreciated. Thank you.
PNath
you should have a drop trac bar bracket and a drop pitman arm.the drag link and the trac bar should be at the same angle to keep bump steer from happening.
