Touch Up?
  • Thread starter Thread starter buckinbronk
buckinbronk
I am thinking about getting some of that touch up paint in the little tubes with the brush to fill in some chips in the paint. I was wondering if anyone has used this product before and how well it works.
It works well. Not perfect but makes it alot harder to see at a distance. If you are picky you can also buy some clear to put over it after you use the touch up paint. Let it dry a bit first.
Yeah the stuff works pretty good for me. I've had some of it flake off. DragonDave is right too, from a distance it's great but when you get close up it looks kind of crappy. Color matching is definitly an issue unless of course your Bronco is black like mine. Pretty hard to mess up black. ;-)
Have fun painting!
Ed
Allright guys thanks for the info. I think that i just might use the touch up paint then when i find some time i will just paint the whole truck. Also have any of you guys used this stuff called miracle paint? You are suppose to be able to put it right over rust without sanding the rust down, and it hardens so you are even able to use it as a filler.
Never used Miricle Paint before. Used a lot of bondo though. ;-)
Let me know if you use the stuff and how it turns out.
Eddie D.
