Z zwhitehead Guest Oct 4, 2004 #1 I installed a new 302 in my 87 Bronco and it has a F303 cam, what do I time it too? Zeb.
B BigNasty Guest Oct 6, 2004 #2 Should be like any other cam, as long as it was assembled at the stock degree mark. Start with 10 degrees BTDC and go from there.
S sweepersrgr8 "GET ER DONE" Oct 7, 2004 #3 Did you degree it in, or did you just install it straight up? The F303 recommends degreeing for optimum performance. Start with 10, but you may need to advance the timing upto 4 degrees.
