tail light trouble
brucef250
hey all .. i hope every body is doing fine...i am having trouble with a 1987 f350 ...i just put new led lights on the back...every thing works great ...but with the brake peddle pushed and right turn switch on , the left brake light goes out compleaty...??? i have no clue whats going on ..also the brake lights are only hot with the key in the on position...thanks in advance for any help...bruce
Have you checked to see if all grounds are making good contact at the tail lights? Could be a poor ground or a short circuit somewhere from steering column to lights. You may want to check out the brake light switch at the brake peddle. Not sure if thats a problem, but it would be another place to look.
