bluryeyes
:unsure: The 302 and 351 starters sure looked the same. The 351 seems to start ok. Do you think I should change them back. It seems that the problem was a shot battery because the 302 won't start even with a jump, the same problem with the 351 before I switched the starters. The battery, the bad one, comes to full charge in about 2 minutes after failing to start either vehicle.
