i have a 1979 f-150 4X4.
it seems that the rear axel has slop in it. if i get under the truck
and grab the drive shaft it has about 1/2 inch of play before it seems to
start to turn the rear wheels. i checked the u-joints they seem to
be firm. look fairly new. no play in them at all. When turning the
drive shaft with my hands you see the entire shaft move as one but feel
like the pinion gear hits the tooth on the ring gear. i can grab the
drive shaft and all is tight. u-joints are good no slop in it. i know it has a
locker, just do not know what kind or type. if i turn tight either way
the inside tire chirps unless i am real easy on the gas. the tires are
38.5 x 15.5 X 15. how can i tell if it has a locker besides turning tight
and hearing the inner tire squeel. i can not cake it apart if thats the
only way. not untill i have a lot more time.
Thanks.
Thanks.
