Radiator
lukeyboy60
This is a stupid question, but is there a difference in radiators between a 302 V8 automatic and a 302 V8 standard three on the column?
The only difference i can think of is using the automatic transmission cooler that's on the side of the radiator with an automatic.
early (66-68) 289 V-8 Broncs had a different rad with a separate expansion tank in the top rad hose, other than that, G.Q. is correct.
You can use an auto trans rad for a manual truck with no problems.
