eltigrekid
i got a six inch lift for my 84 ford bronco witch is same as f-150 and i put the ad-a-leaf in and then took the stock riser block out and put the new one in but im not shur if i was supposed to leave it in because it seems like the axle should be pointing or more inlign with the drive shaft. im not shur if the is bad for it or wrong because it was not in the directions. thanks
