JBronco, the Positive Crank Ventilation valve is located in one of the valve covers it is attached to a hose that is connected to the vacuum created in the intake manifold. When replacing the PCV valve make sure you also install the new rubber grommet that should come with it and check the hose for blockage. Have fun.
Henk from Oz
