I am planning on changing my oil pan gasket this weekend and thought I would just go ahead and change the oil pump. Which one you think I should get:
OIL PUMP for a
1989 FORD TRUCK BRONCO
Normal Stock
Special Order
Not Available
Item Part
No.
Warranty Core
Value Unit
Price Availability
Store Web
MELLING M-68 3 MO $15.99
MELLING
HIGH PRESSURE M-68A 3 MO $43.99
MELLING
HIGH VOLUME M-68HV 3 MO $35.99
MELLING
HIGH VOLUME 10688 3 MO $57.99
SHAFTS ARE EXTENDED INTO BOTTOM COVER FOR SUPPORT.
RELIEF VALVE CUP PLUG HAS BEEN REPLACED BY A SCREW IN
PLUG. INCLUDE I/S SHAFT. MAY REQUIRE MINOR OIL PAN (MORE...)
MELLING
OIL PUMP KIT K-68 3 MO $24.99
EXCEPT HIGH VOLUME & HIGH PRESSURE
MELLING
OIL PUMP KIT K-68A 3 MO $23.99
USE WITH HIGH PRESSURE PUMP
MELLING
STANDARD VOLUME 10687 3 MO $58.99
HI_TECH OM-68 2 YR $29.99
HI_TECH
HIGH PRESSURE OM-68-A 2 YR $49.99
HI_TECH
HIGH VOLUME OM-68-HV 2 YR $36.99
Thanks for you Help
OIL PUMP for a
Normal Stock
Special Order
Not Available
Item Part
No.
Warranty Core
Value Unit
Price Availability
Store Web
MELLING
MELLING
MELLING
MELLING
MELLING
MELLING
HI_TECH
HI_TECH
Thanks for you Help
