That would be a Ford 8.8 , drum brakes,31 spline axles,more than likely 3:55 gears and possibly the ford traction lock unit which is a clutch type limited slip posi which has a big s shaped spring in the middle of it which you can clearely see after removing the cover . Hope that helps
