D
DanaDRD
I purchased some Superlift lift blocks to raise the rear of my 1982 Bronco 2. The installation instructions that came with the Superlift block does not say anything about the factory wedge used on the stock Broncos suspension system. Do the Superlift blocks install between the stock factory wedge and the leaf spring, or do you discard the factory wedge? How will this effect the differential pinion angle?
