Col Klinx
Well I finally got plates for my truck and after filling it up ive discovered it leaks gas pretty bad until it gets to about 3/4 tank. Iam pretty sure its the sending unit seal but i don't know why. I put in the new gasket and i think it bunched up and is causing a leak. iam going to drain the tank and drop it wendsday (tommorow) and check it out. Iam hoping this is an easy fix and a cheap fix cause iam broke also i need the truck to get me to school among other places. So has anyone ever had this happen before or have any ideas on how to fix it? Also does anybody know what the engine RPM should be at idle? Ive tried to set it because it seems high but when it goes down it goes way to far. It seems to be really really touchy. My friend had some sears engine tester which ahd a tach on it and it would go from 600 to 1000 but i couldn't get anything in between that. i was thinking 700-800 would be a good place to start though. So would that mean i need to adjust the idle mixture to get it to idle down a little more (the carb is a holley 2 barrel)? And where would i find out what model transfer case is in my truck? besides the leaky tank and moderately high idle the truck runs great.
