Just got it
Burns
I just bought my first vehicle, a 1990 Ford Bronco XLT (stock as far as I know of, save for radio). When the heater is on for more than 2 or 3 minutes, it starts to make a grinding/humming noise. Any ideas on the cause? Maybe from not being used for a while?
Also, I'd like to know what are the biggest size tires/rims I can mount on it?
Any help'd be appriciated. Thanks.
Welcome to the Zone
. Good choice for a first vehicle B) Sounds like a nice truck. Be sure to post some pictures.
As for the heater noise, that is the fan motor. It sounds like the bearings on it are going bad. It is mounted on the firewall passenger side. Three screws and it's out. They are cheap, but check it when you pull it out.
Burns, if you still want your VIN deciphered, post it in the "VIN deciphering thread" i made for ya, seabronc can help ya out! B)
Cha,
In reference to tire size.. I have an 89 stock height w/ 32x11.50.
They do rub against radius arms. I have been looking into
(investment w/ tire expense) purchasing extended radius arms
(i.e. Rancho "check out RS 9000X adj. shocks too) to allow full travel for 33's.
33 x 12.50 on a 15 is a good optical fitted for the size of the Bronco wheel wells, "in opinion"
Good Luck, Have had mine for a good 7 years. Keep up on-er
and she will stay faithful. [-o<
