well i finnaly figure this out. there is a small hole at the base of where the the cylinder goes into the steering column, turn the key to on(not run), push somthing up there like an allen wrench and then it should come out but may require alittle force, as mine was almost stuck i ended up pulling the wheel so i could pry it out from the bottom but it finnaly came oose
