how does it run warmed up?or going down the road?does it idle real high only?
you might have a vac leak.
I know a way to check for vac leaks that anyone can do but you have to be careful cause carb cleaner is flammible:start up your truck put the hose on a can of carb clean and very tediously spray around the carb and intake if the motor revs and smooths out at any time there's your leak.please be careful.
check your choke like he said 2 carbs same prob it's problly not the carb.
to set your floats start it up let it run shut it off and take out the big screw on the side of the float bowl gas should just fill the threads,if not turn the screw on top out for more or in for less.
is your timing on?not by ear either,i don't care what people say about timing by ear it only works sometimes,unless you know your truck and what your doing.
I know a little about the holley's and so does seabronc so if you run into some probs just ask.I also left a link in how to's holley lovers check it out and get to know your carb they are great once they are right
good luck
