S
sbingham2
Yesterday I replaced the flywheel, clutch assembly, and rear driveshaft on my 1970 Bronco (302 V8, 3-speed). I also bought the Hurst floor mount shifter. I got everything back together, and went to install the new shifter, but found that both of the levers on the transmission were frozen. They won't budge at all. All I did with the tranny was pull it and put it to the side while I did everything else. It worked fine prior to pulling it into the garage to start working. When I start it and let out the clutch it stalls without budging an inch. Even if it were stuck in 3rd gear I could still get it to roll. I have no clue what happened. Could it be that I ben the input shaft and something inside the transmission is now out of whack? If anyone has any suggestions please let me know. After all that work I'm itching to get it back on the road!!! Thanks!
