Header Clearence
  • Thread starter Thread starter ROCHMPR
R
ROCHMPR
Hello out there! I got a question about clearance. I have a '72 and I'm putting full width axles, front and rear. The front axle is a reverse cut high pinion and the housing is hitting the header on the driver side. I don't know what kind of header it is, all I know is that it's in the way. A standard cut fits in fine, but it's still close. I would like to use the high angle, but I don't know what header I can use. Has anybody run into this problem? If so what can I use. :unsure:
You might want to post a tread on classicbroncos.com
There's a unch of old bronco guys there with lots of info.
Good luck
