Gas In Oil
  • Thread starter Thread starter Bronc Oh
B
Bronc Oh
I have a 93 5.8 that won't start , there in raw gas in the plennum and all cyl. but # 8 is worse. if you clean plugs and dis connect fuel pump it will run til it runs out of fuel , but with pump on it will flood instantly . Injectors are good. any ideas. Thanks
replace your fuel pressure reguator that is located on the back of the drivers side of the engine. it is round and has a triangle on the bottom where it attaches tot eh rail. that should be the problem
yea the fuel pressure regulator just had to replace mine I was running at 80 psi in the fuel system when should be 28-45 psi ..
Thank for the info . that was the problem it's running great now.
