Fuel Tank
  • Thread starter Thread starter bGILLEN1
bGILLEN1
I'm tired of smelling gas inside my cab, need info on removing stock tank, placing new tank under neath bed, also about putting shoulder harness seatbeltin my 67' Ford F100......
[snapback]7541[/snapback]​
Your gas tank is currently behind the seat, right? If so, pinch off and remove the lines and hoses. As to replacing it under the bed, good luck. You might be able to fit some later model brackets for the tank under the truck.
Try replacing the gasket under the fuel gauge sensor. That should correct the fuel smell issue.
