B
BroncoBlues
This '73 302 has run sharp as tack for years, at 209,000, second owner. Recently, it began running rough, and got worse and shut down, and towed. But, it restarts fine after sitting. Tuned-up, rebuilt carb just now installed by mechanic as thought that might be the problem as getting overload with gas. But as usual, idles fine, sharp, says mechanic, but as soon as accelerates or load on, its gets really rough. If accelerating further at idle it seems to smooth out a bit once past the roughess point of running. It is more noticeable on the road and a climb, and it seems the longer it runs the worse it seems to get. Could it not be firing or misfiring on a cylinder? Gas building up in one cylinder and not being burnt. Compression tested 170s, 155s, and a 135, prior to installing rebuilt carb. Coil okay, wiring seems fine. Not certain if distributor bad, timing chain off a bit, or what? I was thinking bad fuel pump? Mechanic doesn't think so. I have worked with external engine repairs, ei. tune-ups, etc., for years, but can't quite figure this one out, nor have had a vehicle ever act up like this before. Changed point, condenser, button, and cap, again. Has 7mm wires solid wires. I had a for sale sign in the window, but not at the moment until I fix this. Thanks for any help!
