C
CaptainHalitosis
Hello Everyone. I am new to the forum and I enjoy it.
I am having ongoing problems with my 93 Bronco (5 liter, manual trans) and none of the locals are able to help me. Maybe you guys can.
I don't know if these are related, but my gut feeling is that they are somehow.
I was frequently blowing the fuse marked "Stop/hazard lamps, anti lock brakes, speed control, stop sense for: electronic engine control" when I stepped on the brakes. I traced the wires, replaced the bulbs, cleaned the terminals and replaced the brake switch at the pedal. None of this worked. On occasion I could go for three or four days without blowing a fuse, so I thought I could live with it. It then quit blowing the fuse as if by magic.
Three months later, I replaced the wheel bearings on the right front of the vehicle. When I went down the road for a test drive, the ABS light came on. When I stopped and shut the Bronco off, it would not restart. I blew a Maxi Fuse under the hood. This fuse is for ignition and ABS among other things. I started it for a week by arcing across the switch on the fender. Today, I fixed the starting problem. To make a long story less long, it appears that the ABS sensor was grinding on the fins on the hub. I tapped the sensor back with a hammer and I no longer blow the maxi fuse and can start the vehicle without the use of pliers.
I now have the ABS warning light on the dash and I am back to blowing the "Stop/hazard lamps, ABS etc." fuse.
Does anyone have any idea what this might be? I have disconnected both Abs sensors and that didn't help. I would really like to fix this without taking it to the Ford Garage and paying a gazillion dollars to find out it is something dumb.
Thanks -- Mike
Thanks -- Mike
