C-4 Kickdown
  • Thread starter Thread starter lcac24
L
lcac24
I need some info on the C-4 kickdown. I have 1970 with a 93' 5.0/C-4 and I am not sure how it is supposed to work. Any help would be appreciated!!!
Assuming that you are running fuel injection on the 5.0,
You will need to find a cable operated kickdown conversion.
The factory kickdown rod won't work with the FI.
I have had great success using Lokar products for this type of conversion.
Check with your local speed shop, they should be able to help you out.
I believe the part number you need will be Lokar KD20C4HT
