Brake Rotors F 150 4 Wdr
af ford able
can you seperate the hub from the rotor with a simple block of wood and hammer i have never tried this method before the truck is a 4 wdr just trying to save a few bucks if i can. [-o<
If they are anything at all like the ones on my 93 Bronco I dont' think so. I replaced them about a year ago and everyone kept telling me that is what I had to do. The problem was that they wouldn't come apart. Turns out that they are one piece and go for about 100 bucks each......... yeah it sucks... good luck
I changed mine recently on a 91 f150 with auto-hubs and in order to get the rotor apart from the hub assembly I had to disassemble the hub mechanism (which allowed me to take the hub casing and rotor out)and then take a air hammer and punch out each stud and then the rotor and hub casing came apart. Just remember when you put it back together to press the studs in straight.
