JerkyB2K3
Well, if anyone recalls, i was having troubles with erratic idle. Anywho, here goes. Changed my gastank and ended up plugging a fuel filter 30 mi. from home, so i drove it home with the plugged filter. Carboned up the Idle air ctrl valve, so i took that off and cleaned it up good, and that solved my funky idle. However, the bronco now has troubles with a bad hesitation. Figured I may have plugged another filter, so it put a new one on. Now, the hesitation is only under load and at any engine temperature (cold or up to operating temp) and it will rev up fine in neutral or park. The truck is a 1990 5.0L (no mods) with a rottenmatic. New tank, old pump, new fuel filter, no luck. Any Ideas what could be wrong? Another bad sensor? Something else in need of cleaning? I'm lost as to what the problems could be. I think i read in another topic something about the Intake Air Temp sensor causing a hesitation, but I don't know much about that, let alone where its located and how to test it etc. Any help is greatly appreciated, thanks. Oh yeah, and there aren't any codes being thrown at me. Thanks again.
