Aod Kickdown
  • Thread starter Thread starter CAcruddy
C
CAcruddy
I have a '75 EB. currently with a C-4. I want to upgrade to an AOD.
What I have discovered is that the kickdown cable on an AOD is considerably different than that of the C-4. The throttle location is paramount to the proper operation of this transmission. Next throw into the mix, that an Edelbrock carb claims to require a Lokar custum kickdown cable to work with their carb application with an AOD. Between both of these scenario's I am having a few hesitations about taking on this conversion. It appears that this conversion is a little more complex than described in the Tranmission swap article in Bronco Driver Magazine.
Down the road, I definitely would eventually like to swap a 351W with an edelbrock650/manifold some day.
Question: (1) Has any out there converted to an AOD?
Has anyone out there with an AOD replaced their Ford carb with an Edelbrock aftermarket carb?
If so, how much of a pain was this kickdown issue?
(2) What other hurdles am I instore for with this AOD swap?
Any help from anyAOD trail blazers would be appreciated.
thanks-
CAcruddy
Driveshaft length is also going to be an issue cause the AOD is longer than the C4 . I just converted my 89 from an AOD to a C6 and it was a pain . Different drive shafts , Neutral safety switch wiring, The kickdown system , And the shifter detent in the steering column still isnt right , I had to give up either park or first gear so i went with not having 1st gear till I can find another column . Hope that give ya an idea of what your in for :D
