R remer Guest Feb 19, 2004 #1 ( can any one suggest a solution. i replaced the alternator, belt and voltage regulator. think i should replace the harness
A amcabbott Guest Mar 31, 2004 #3 / check all your grounds, all your light sockits, & all your extra gadgets radio etc. as you may have a large load pulling the power down also check the dash voltage regulater it has its own and they go bad.
