F
FLYFSHIN
Ok, so I'll share with you something I found off FSB regarding FIPK setups. There's been a number of discussion strings on K&N's, and I've been holding out. Basically, this will save you 140+ bucks of your hard earned money and give you the same results, and you can make it just as pretty.
Order K & N part number RF-1012. I got mine from http://www.performanceintl.com/ for 53 bucks. Pick up a 1 foot length of 3" aluminum pipe, and 1.5 ft of 5/8" automotive hose from your local autozone. Grab a 5/8" coupler too.
1. Start by tearing the stock airbox out. Leave the twin hoses that originally connected to the airbox in place.
2.Cut the 12" pipe in half. Paint it. Put one 6" section in each of the rubber hoses, and the other ends into the K&N filter. Tighten clamps.
3.Trim and connect the 5/8" hose to the breather using the coupler. Run it into the back of the K&N filter.
4.Start your truck, listen to the nice sucking sound.
5.Rev it up. Listen to the nice sucking sound.
6. Use 12 of the 140 bucks I just saved you to buy a case of beer. Drink it while listening to your truck.
