96 Ranger crank and cam sensor replacing
dsaseattle
I have a 96 Ranger, the hillbilly repair shop says that 1 need to change the crank sensor and if that doesn't work then I need to replace the cam sensor. This is a new problem that came up after the shop replaced the timing belt. Now the engine has no power and idles rough, but the check engine light is not on. Where are these located and do you have any helpful hints on changing them?
