85 Bronco Ii Can't Get Any Spark
  • Thread starter Thread starter rjwright
R
rjwright
:( It shut down while I was driving and I haven't been able to get it to start again.
I've changed the control module on the distributor and replaced the coil. Still no spark to the plugs. Any ideas? It is 4x4 and has a 2.8 v-6 with a/c and a manuel transmission.
Check under the pass. side carpet up on the firewall. Ther you will find a little black box w/ a white button on top. Push it and see if it will crank. It is a fuel pump reset and my wife's BII does that crap all the time! Just a suggestion. ;)
