84 FORD F-350 PICKUP DUEL REAR WHEEL CONVERSION
JDH6621
I HAVE A 84 FORD F-350 PICKUP, SINGLE WHEEL REAR AXLE, 2 WHEEL DRIVE, IN WHICH I'D LIKE TO CONVERT TO DUEL REAR WHEELS, FOR MORE STABILITY WHEN TOWING. I UNDERSTAND DUEL WHEELS WILL NOT JUST BOLT ON AS IS. MY REAR AXLE ASSEMBLY IN THE TRUCK IS A DANA. I THINK IT IS A 60 SERIES. THE NUMBERS ARE 3.73 RATIO, E4TA, 60519-4. CAN I RETAIN THE REAR AXLE ASSEMBLY WHICH IS IN THE TRUCK NOW, AND JUST CHANGE HUBS AND DRUMS, FROM A DUEL REAR END.? OR DO I NEED TO CHANGE THE WHOLE REAR AXLE ASSEMBLY? BODY- BED MODIFCATIONS ARE NOT A CONCERN.
2ND QUESTION--AFTER 1987 DID THEY MAKE DANA REAR AXLES , THAT THE DRUMS COULD BE REMOVED, BY SLIDING OFF THE HUBS. IF SO WOULD THESE FIT THE EARLIER DANA HOUSINGS, AS IN MY 84 ?
THANKS FOR YOUR TIME GUYS, JOEL
