V
veniz23
1982 full-size, 302w, 4bbl carb. When the engine is under load(low-vacuum) the A/C switches to the floor vents(which are the default vents I assume) instead of staying on the dash vents. One of my problems I assume is that the vacuum reservoir is not hooked up correctly. I guess it is the reservoir(little black ball mounted on pass. side fender well that has 1 hose coming out of it). There is a black plastic valvle mounted to firewall(pass. side) that has 3 vacuum outlets. Here is a little drawing. Maybe someone can point me in the right direction. I have been trying to figure this out forever and no one seems to know the answer.
