79 Ford Van Ignition 460 CI
lc4pilot
Troublshooting Question: When cranking the motor, especially when cold or after extended periods of non-use, the motor will not fire while the starter is cranking. When the key is released to the run postion, the motor will try to fire or actually start running. I've replaced the ignition switch and the problem continues. After the motor warms up and is used consistently, the problem seems to be less noticable. Any ideas?
