75 Bronco
  • Thread starter Thread starter TopMG34471
T
TopMG34471
Recently RETIRED from the Army and bought a 75 Bronc. It currently has 1/2 cab hardtop. Was this the original top? It looks like an aftermarket special. Looking to remove it and replace with a full cab. Is this a simple option? What is the best lift kit for about 3 1/2 inches?
As long as the original hard top bolt holes weren't filled, you should have no problems bolting a wagon roof on.
You can always try your luck on E-bay.
There are at least four listed right now...
Hi...got a full top for sale with tinted windows and chrome trim. Not in perfect shape but very usable. Top should bolt in as long as there are holes along the top of the rear quarters and the brace pockets at the rear are open. Can hook you up with a set of quick release fasteners for the top too. Depending where you are....top is in NE Illinois.
I also have a top with all related hardware for mounting. Contact me if you're interested. Located in NW IL.
Congrats on that retirement Top..Were you a Topkick?If so I wish you good luck!Previous posts all had good advice but you also may want to check out broncoconnection.net.And also keep that halfcab.It is a very rare piece of sheetmetal and sells for real good money.Good luck!
i like the full top more and i like skyjacker lifts the most
