4x4 Stuck On
bluesman17
I have a 92 bronco with electronic 4x4 and its stuck on, i no longer hear the click on the side of my dash. Anyone have any ideas?
Welcome top the Zone.
Does the rear window still go down with the key in the back? Also do the power door locks still work? If not you may have a bar breaker / fuse. If the door locks work but the window does not then you have a bad wire. Probably under the hood on the driver's side. IF Ford used the same wire color you would be looking for a black wire with a white stripe.
If everything is working then you may have a bat relay at the transfer case.
