1995 Tailgate Help Please.....
bcdrac
Rear window won't go up or down. Motor working or at least I think it is. Took motor off and gear spinning when button pushed but wont work window. Any suggestions. This is my sons 1995 bronco this pic is mine a 1994
Welcome. It could be the wires, i had the same problem it wasnt the wires, i just needed to flip the buttom than insert the key than it went down.
Welcome to the Bronco Zone!
It sounds like the motor needs to be rebuilt or replaced. There is a guy on eBay that sells window rebuild kits that are around $10.00. You might want to try that first.
after you got the motor out and torn apart,it could be the triangle metal lookin thing that goes into a white plastic piece that goes to the motor..the metal thing spins and its suppost to spin the plastic piece,if it doesnt put some little pieces (3) of metal between the metal and plastic piece so they both turn at the same time...i just did this to my buddies 89 and fix it..cuz the window wouldnt roll up or down, but you could here the motor working..hope this helps
Bronco rear window problems - someone should write a tech article on how to fix these. I agree with audie.a that it sounds like your gear is shot. Local auto parts store should sell replacement gear for around $10.00. Once you get into the tail gate, might as well give every pivot joint and roller a good coat of white grease while you're at it.
