1988 Bronco11...need Front Suspension Liftt
  • Thread starter Thread starter johnnybronco11
johnnybronco11
i have 1988 bronco 11 4x4 ...have put on new hankook dynamic tires ....had little prob doin rear suspension lift ...got up 2.5 inches for very little money ...need help doin front .want to get aboput 1.5 inches of lift ...was told go variable rate coil springs in front ....also have been told can just replace coil spring blocks under sprin with larger one ....any help will do and where to get parts can email me at [email protected]
to tell the truth you'll be better off just buying the front lift only if you use it as a on road driver too. with the TTB frontend there are a few drop brackets used to help keep your front inlined. Even the small 1.5" your looking to get will throw it all out of whack.
yes diffirent spring rates will gain you lift. The cheapiest way will be to find coil spacers. you'll just have to look at offroad places to find them. www.broncograveyard.com or www.jcwhitney.com may have them.
