1979 Bronco Fuel
chetney
Hey the tank on my bronco i just got seems to be really tiny, maybe 19 max....
i was doing some searching on the swaps and found a parts list on JBG, but all prices have changed or am i looking at wrong things?
how hard would it be to swap the 19(or what ever it is) to the big 33..
i search JBG this is what i find.
33 Gallon Steel Gas Tank Item # 20203 $105.00
Skid Plate 33 Gallon Item # 20254 $115.00
Tank Strap, Upper Item # 20250 $15.00
Sending Unit Lock Ring $7.00
OEM 33 Gallon Sending Unit 1978-79 Bronco 125.00
367 seems to be a bit high on a new gas tank? but would be worth it alot more miles out of the 400.
Or would the plastic
33 Gallon Tank, 1978 - 79 Plastic one be better, and do i need the emissions hole or not?
what things am i missing?where can i get diff parts cheaper?
who made this skid plate below? and anyone else make them and how much?
thanks
kevin
i made one out of steel diamond plate just like that,just go to your local fabricator with a brake that will bend thick steel or aluminum and copy what's on that pic.
aluminum diamond plate is some expensive stuff,but light weight and pretty
You would not need the upper straps as they are the same for 25 or 33 gallon tank. I swapped my 25 for a 33, found everything in the junkyard. I believe 80 and newer 33 gallon tanks will fit the '79 as well and I have seen a lot of newer Bronco's with 33 gallon tanks. As for the emissons hole, check your 25 gallon tank, if it has a small tube about 4-6" down the filler neck on the LH (front) side, then you have an emissions tank.
