1973 Bronco
  • Thread starter Thread starter WPM1958
W
WPM1958
There is a small block in the brakeline that separates the front brakes from the rear brakes. I don't know what this is called but mine is stopped up. I don't see one of these in your catalog and I was wondering if you have something that will replace this. You have a #12560 adjustable proportioning valve. Is this what I need?
You need to contact Jeff's via their contact us link or call them direct. 248-437-5060 or 248-486-1760. You can also try LMC truck, but I don't happen to have their number on hand.
Its called a brake proportioning valve. Call Duffs, Bronco graveyard or Tom's Bronco parts. They all have stock replacements.
FYI:
If you go disc in the rear some day it will need a new disc brake type proportioning valve to give proper pressure.
